dadandfourmore
I am a new member so bare with me. I just bought two old Seadoos; 94 xp and a 96 spx. the Xp ran for a minute during test drive, but now it wont go when you give it gas. Motor revs but its like a clutch is slipping...I know it does not have one though. I am pretty handy so I took the motor out last night thinking I would find a stripped shaft or impeller. The PTO pulley (female splines) looks good, the drive shaft; both ends are fine so no luck there. I will make a pulling tool tonight to get the pump off to inspect the impeller, but unless that is stripped, I'm at a loss. My experience tells me if it was in the engine itself, there would be a great deal of noise and probably would lock up. Am I correct in looking from the PTO wheel back? If the prop is good, I really want to find something wrong and fix it before putting the engine back in.
Also, found a very small oil line not connected coming of the oil pump. It is right below the larger main oil line. This line is probably a 3 or 4 mm line, but I cannot find where it ran to. Any help.
Thanks,
Thanks,
