Jfrymania
First off thanks to Bmann and Rfoster on their help so far. I do have some more questions regarding the cable by the jet where it goes into the transom. I can see the cable going into the transom and when I pushed the gate up it would hit the pipe on the cable and not open. After thinking of what Bmann and Rfoster told me I decided to disconnect the wire to prep for installing the new shift lever (I broke the last one trying to launch the boat). That when I noticed the pipe is a outer sleeve. So my question is should you be able to see the cable goin into the transom or do you just see the pipe and sleeve (mechanical vocab?)? I can't upload the pics for some reason, the iPad will not search for files. I will try to get them uploaded. If the sleeve connects to the transom please explain how to connect it there. Again, thanks for the help!
'99 Speedster SK
Jfrymania
'99 Speedster SK
Jfrymania
