alright drilled and cut carb bolts off took about 4hrs damn stainless bolts well the big problems is the carb still does not want to come off its like frozen to the manifold i was unable to drill and cut with motor in ski so i took off exhaust unscrewed motor mounts and rubber boot on shaft tried to lift motor all the way out and the shaft came loose from the impellar will this whole package come out or is there a way to diconnect the shaft from the motor i was able to lean and tilt motor on side to cut bolts
BUT AGAIN THE CARB WILL NOT COME OFF!!!!can i take the bolts that are behind carb what will that do its appears to be something for the oil pump maybe is there anygears in there please help wanna get her in the water the longer it sits the more the wife wants to sell NNNNOOOOOOO!!!!!!
