Sebastian Bluecrew
Matt, chime in..
This is my current setup..
1997 Seadoo SP with 720, Factory Performance pipe and ECWI Microtouch, WSM piston kit .75mm overbore, dual 44mm Super BN jetted at 132.5 low/120 high @ 20PSI pop-off,Mounted on Westcoast intake manifold, Ocean pro vortex filters, 150psi x2 , Solas X-Prop 17/24, Worx Intake grate, Sunoco GT260 100 Octane race gas cut with 93 octane about 50/50 blend. pre-mix Klotz Super techniplate oil with a bit of Klotz BeNOL mixed in to it and I also run a couple ounces of Klotz Nitro (Nitropropane/nitromethanol)
This thing is a total monster... I'm guessing I am over 50mph, and she is just nasty.. Pulls so hard, but it seems I have so much more horsepower left over even with this prop.. the 16/21 Solas I just removed would tach out at just less than 3/4 throttle at like 43MPH so I bought this steep prop.. It still hits the rev limiter at about 7/8 throttle but my top end went through the roof, the pump is hooked up, i just have to keep from holding it wide open because she bounces off the limiter... Could I still have more horsepower than prop? Its new jet pump bearings, new wear ring, new neoprene seal, and new carbon seal.. Guy at Impros told me to get rid of the carbon seal is it total garbage, and go back to the bearing carrier to avoid sucking any air to cause cavitation.. But I know some people out here will disagree.. Impros is hesitant to pitch this if I send it to him because he said first i need to find out why it is hitting rev limiter when I'm topped out ,when it normally takes $10,000 to build a motor that will even turn a 17/24 xprop.. When I had the 16/21 Solas on it, I couldnt get past 43mph and I could never hold it wide open or it would just smack the rev limiter, now I have to be well over 50mph, but havent clocked it.. I know it is much faster because I have to hold on for dear life... What would you do? Matt B, (or anyone) what did it take you to turn a 17/24 Xprop and what would it take to max out an impeller??? If the answer is "You are cavitating" then what will happen if I resolve the cavitation? Will I gain even MORE top end? Because it sure is scary on an SP at this speed.. Or Do I need more prop? I want more top end, I dont want to have to think and listen on where to hold the throttle so i dont lay on the limiter for the entire time while I am racing someone at 55mph...
