gti 130 wow
I noticed that in order to reduce the sound , the GTI air intake uses pipes and hoses to give a restrictive , zig zag path .
Here are some things I am thinking about trying so get less restriction at the expense of more noise .
Also , I realize if I keep the stock air box and just make it less restrictive , I don't have to monkey with the straps that hold it and the fuel tank down .
1:Remove the air intake silencer hose item #49 to eliminate the zig zagging air path
2: Remove item 49 and replaced it with a bendable pipe lined up with the air input pipe but 12 inches away to get less restriction while maintaining some protection from water ingestion .
This is my favorite .
3: Just remove item 49 and just run hose from the air intake pipe to the pipe where the air exits the box.
So good idea or am I barking up the wrong tree ?
http://www.seadoopartshouse.com/oemparts/a/sea/546b811af8700222241ab469/engine
