Missing check and relief valves
So while rebuilding my carbs I was looking at the parts diagram for the fuel system and noticed I am missing both valves from my fuel system. And im having a hard time finding them or a suitable replacement.
I think they are located where the vent hoses attach to the hull.
Thanks, you are correct. Pulled them off the hull and the valve below the hull line was full of what looked like syrupy gelled fuel. Sprayed the valve out with some carb cleaner and compressed air and seems like it works now.
Yes, I need to check those valves and replace the hoses as well. Is that the pressure relief valve that goes out the side next to the battery vent?
