LSC101
Boat: 2000 Challenger 1800
Motor: Mercury M2 jet 210hp
*power head replaced new in 2013. One valve block replaced at time of power head replacement.
Current issue: Typically in very humid weather when coming off plane (between 3000-4200 rpm) the power level surges up and down. Mostly feeling like it is loosing power only to come off plane. After I come off plane it idles fine. Take off (acceleration) and top end is excellent. This only happens when de-accelerating. I don't know if the humidity has anything to do with this issue, but I just happen to notice the majority of the time it is a very humid day or evening when this issue occurs.
Could this be one or more of the (reed) valve blocks is bad?
When I replaced the power head in 2013 it was because of a blown cylinder. The mechanic replaced only one valve block because it was corrupt because of the cylinder seize. Since this is a mid range issue I can only assume this may be the problem. Anyone have any other suggestions?
