UnityRacing
Ok i'm looking at buying a 96 Challenger this weekend with a blown motor, bad steering cable, and botched seats. $550 w/trailer
I have done about 20hrs worth of reading on here so far and have everything in order, on where and what to buy EXCEPT the seat foam!
The seats in the boat are shot, about the only redeeming factor is the plactic pans are all there. The foam is worse off than any other I have seen on here so far. The vinyl is mostly missing, and the foam is split and largely missing. The port side arm rest for the rear seat even has some of the white styrofoam missing.
There are a ton of posts on here about recovering the vinyl, but not too much on the foam itself, other than to cut out the bad part and replace with new.
I guess what I want to know is what is needed to replace the foam completely? How thick? What density? Links are awesome if you have some. Also what styrofoam is used under the foam everywhere? There seems to be more than one thickness for everything, the arm rests look to be much thinner than the seats themselves. What can be done about the bolsters?
Sorry if I missed something somewhere, but I did try to search first!
