Storage
My 2003 Islandia, 2 Stroke 2003 Mercury 240 EFI
...did not rev over 1,600 rpms, and has NO Throttle Guardian! First Mercury Dealer, kept ALL last Summer, 5 mos, and said his Computer... showed EVERYTHING...>Normal! Could Not repair, SO I took to 2nd "Country Man" mechanic that is Older, and works on ALL outboard engines! Kept ALL Winter, and in early March..... he got the engine to Rev up another 1,100 rpms, to 2,700 rpm.....but Sputters & engine dies over 2,700.... He Gave-Up! 3rd.. Took to SeaDoo Dealer March 23rd, and emailed Svc. Mgr. 23rd April.... he replied, saying his Mechanic said the engine was a Mericruzer, but STILL had on scheduled for Service last week in month. Today 2 Months LATTER (3 Months total) I went over and my boat had NOT been moved 1 inch, from where I left it in March, so I brought it home! I am 100% Disabeled Vet, and am so FRUSTRATED that I can not get in the Engine compartment to check wires myself, as from ALL (hrs & hrs) I have Searched.....it appears that the Port side "Temp Sensor" may be the issue, as I read it will PREVENT the engine from Reving up, if sensor registers..>. as still being COLD......which makes sense, 2nd, I read that the REV LIMITER may be the issue, and that if the ECU, is ... DisConnected,,,,, that Engine will Run WITHOUT it! If this is TRUE, can some one tell me where & COLOR of Wire, ....to Temporarly disconnect it ...." to determine if "Electrical" is the issue? Dr Honda, .......AnyOne have advice? Thank you...... Bill
