UKGlenn
I'm after some advice.
I have a 6 month old broken alternator belt!
I had the boat in the sea a couple of weeks ago and on the way into harbour the continuous alarm came on. Being only on tickover through the harbour and reading the M2 manual I assumed that the engine was starting to overheat and maybe we sucked up some seaweed. It was flushed fully and I have checked there was no rubbish in the impeller section.
Today I put it on the lake and the alarm came on as soon as I came off the jetty a blast of the throttle to make sure water was being forced through and then power died and the engine became really lumpy, it felt almost as if things had seized up! back to idle and seemed ok again although the alarm still on continuously. Opened up the engine compartment and found the 6 month old Mercury alternator belt snapped and in the bilge.
Alternator rotates smoothly and spins round 2-3 times with a hand spin.
My questions are these..
The manual doesn't mention charging but does the alarm come on if the alternator is faulty?
Is it normal under the guardian system for the engine to feel so lumpy - or could this be due to cylinders not firing at open throttle due to a lack of charging?
Is my Alternator dead? I can't electrically test it at the moment as I will need a new belt but should it spin better than a couple of turns?
Does anyone know the code or length for an aftermarket belt. I bought a 4pk841 from an autofactors but this was too loose.
Many thanks.
Many thanks.
![IMAG3897[1].jpg IMAG3897[1].jpg](https://www.seadooforum.com/data/attachments/25/25218-02d48d3bc387064c0ed549477b75a9b6.jpg?hash=AtSNO8OHBk)
