The ECU doesn't "Turn over" that engine. It's a simple solenoid and key switch. Use a meter, and make sure power is flowing between those switches.
I was not aware. I will try this. I was first told that it was the stator . Then when I looked it up and it said stator underneath the boat. It didn't make sense since It was showing it under the flywheel. One guy said my boat doesn't have a stator and it was my ecu computer that tells everything to turn over. So I tried to find one and find someone to rebuilt it and it wasn't until recently found someone in California who does. But I haven't sent it, I appreciate your advice and would appreciate your input on what that guy said on the stator. The boat just turns and just won't fire up.
My brother and I took off the flywheel and did not see a stator . We also looked under but didn
t remove everything to find the other stator. That one guy I had look at the boat said I didn't have a stator on this boat. That the ecm was controlling everything and telling evreything to turn over. Thats why I was looking to get it checked out. I think you had recommended Motorsports in California to someone else in another thread. I was looking into that to see if my ecm is even working.
I have the round flywheel.
pulled flywheel no stator
no sir
these are the pics when my brother removed the flywheel.
So did I have a stator under the flywheel as well?
