Hi everyone , I am new to this forum and i hope everyone will be patient with me.
It's about a Bombardier Islandia with Mercury 240 M2 EFI engine which has been rebuilt because of a piston failure. Since we have put it back on the boat it does not run more than 2 seconds after it's started.
I have the repairs manual ..... and i have done some Things in order to make it run:
1. I have set correct timing , idle spark timing 9 degrees and maxium spark timing 26 degrees.
2. I have bought a diagnostic tool Mercruiser Rinda Technology , and diagnosed it , nothing wrong (only one question about Knock sensor -the value does not seems to change 0.00 VDC)
3. I have check fuel pump pressure :34 PSI
4. I have check all 3 triggers as the repair manual recommends :everything ok
5. I have tried ( i know it's wrong , don't judge me !!!) ) with starting fluid and as long as a inject the fluid , the engine keeps runing , so i figured it's a fuel related problem or fuel management (EFI ).
6. Battery fully charged
7. No beeping no water in the gas.
8. Oil up to correct level
The accurate description is : ignitions on , i can hear the fuel pump for around 30 sec ,try to start , it crancks starts and dies . If try to start it a little bit accelerated , some times does start and stays longer runing ( 10 secs) but around 3000 -3500 rpm, when release the throttle it dies. If inject the start fuel , idles and runs .
I appreciate any advise !!!
Thnaks
Thnaks
