Mercury 240 EFI M2 wont run
lynnboy021
i installed a new powerhead and it wont run so i got the computer rebuild cuz they said i had 3 drivers bad in the efi... got the rebuild efi back and my injecters still wont fire so i removed injecters and bench test them and they work, also my fuel pump works... i am really stuck with the motor i have spark but just no injecters.... please help thanks...
That engine has 3 fuel pumps. What one did you test?
Also... did you check to see if the injector drivers are OK. Just put a meter on the injector wires, and crank it.
3 pumps i thought only had 2??? well all 2 pumps work (dont know where 3 is to test) and the injecters work cuz i test them but someone said it could be the control box on top of the motor???
The high pressure pump is in the vapor separator tank and it could be your problem. Did you check it? There's a test valve on top of tank, or just remove the hose and hold it in a large container while a helper cranks it. Should have ~34 psi if I remember correctly. Those pumps are $$ (I paid $400), but maybe someone can chime in with a better parts source.
Then you didn't test it.
Just because it makes noise... doesn't mean you are making any pressure.
i removed the injecters with the pump and all and i hooked up 12 volts to the pump and 9 volts to the injecters. when i apply 9 volts the injecters open and gas came out, so yes the pump is working now does it have 40 psi idk but still fuel pumps is not my problem i dont think. i left the injecters out of the motor and i cranked the motor and i dont feel the injecters clicking......... efi and injecters work but whatever tells the efi to fire the injecters is not......
