Seadoodude1, your problem might be the post where the DESS key connects to. I had that problem on my 97 GTX seadoo, it would just cut out while driving, then start right up after I took the DESS key off and put it on again. If that's the problem, just buy a new post at the dealer and then you can cut the wires and replace it.
Back to my Utopia 205, which appeared to be fixed in Feb09 - the acceleration problem is back:
"When just above idle, the engine suddenly cuts out, then comes back, then cuts out. Sometimes it cuts out completely and I have to restart it. When it comes back, it lunges forward obviously, then cuts back again.
As I accelerate further I seem to be able to eventually get it past the lunging and then it will run perfect on plane mostly.
But if I open the throttle to max, it eventually cuts out violently, then lunges forward, cuts out, lunges, etc. - until I reduce the throttle again to midspeed. Sometimes it cuts out completely at speed too, and I have to restart it."
The problem just started again, so I emptied the fuel filter/water separator, and put in new spark plugs, but haven't tried it yet.
Could the problem be the throttle shifter? There is a magnet in the shifter that activates a switch, and when I put it into forward or reverse, it often doesn't activate - so when I throttle-up, the rev limiter goes on. I then whack right next to the shifter a few times, and then try again, and after 2-3 times it usually engages.
I'm wondering if the magnet is suddenly disengaging and then re-engaging when I'm going at high speed, which causes the lunging.
Any thoughts/advice? Thanks.
