vigalass
Gents- need a bit of help. No fuel to the injectors. The pickup pump is spitting fuel fine. The high and low pressure pumps bench tested under 12v fine. When VST is back together in the boat i get no fuel going to the fuel rails. What is the sequence of fuel?... example. Lift pump, to water fuel filter, to high pressure, to low pressure.?
This will help me pull lines and see where the failure resides. Thanks.
Thanks
Thanks
