busterthejetboater
Hi All. My Merc 240efi Sport Jet would not start. Traced to low compression on #6 cylinder. At strip down I found #6 piston crown missing a piece and the barrel scored.
Decided to rebuild the complete engine. I have had the block bored out to 0.015" O/S on all cylinders. I am using the WSM pistons with coating and thin rings. The Merc service manual does not give a piston to cylinder clearance but if I subtract my coated piston size from bore diam then my smallest cl is 0.0068" and the largest is 0.0071". Any idea on this?
The Merc service manual indicates that ring end gaps must be in the range of 0.010" to 0.018". The gaps I am getting 0.021" to 0.022". Will this cause excessive blow by and low cyl pressure readings?????
Any feedback will be highly appreciated.
Thanks
Thanks
