SEADOOBANDIT
Please Guys I need your help. I am such an IDIOT! I thought I would never do this, but got in a hurry and DID it! I have a 1998 GSX Limited and rtan it yesterday perfectly after sitting for over a year. I pulled out from the trailer and putted around the dock for 1-2 minutes and NOTICED it started sinking. UGHHHHHHHHHHHHH I KNEW what happened! The DARN PLUGS ARE NOT IN!
I was Pressing FULL Throttle and it was going 10 MPH, it had very Little power (Normally can go 62MPH). It was only filled with water about 3 inches or so.
It still RAN. I drove it to shore and it would only go 10 MPH at Full Throttle and died a few times and had to restart to get her there. and parked it on the muddy Bank of the lake to put the Plugs back in. WENT HOME, Cleaned out water and THEN WENT BACK TO LAKE TO RIDE IT Thinking it was fixed. When I went back out, IT Started, but it took 5-6 attempts and was BOGGING when I drove it and would only would GO 10 MPH at FULL Throttle!!!!!!!
I did the following:
1. REMOVED the 2 SPARK PLUGS, when I did, little streams of SMOKE WAS Comming OUT Both Spark Plug HOLES.
2. I unclipped a connection that was attached to the PART that looks like a spark plug (Inbetween the 2 Spark Plug) and unscrewed that piece out. It was a little WET.
3. Dried in SUN, then took off plugs and tried to start it with the spark plugs OUT. NO WATER CAKE OUT OF HOLES!
4. Went to Auto Zone and Bought (2) new Spak Plugs and replaced them. Went back to Lake and just put the REAR of the SKI in the LAKE ON the TRAILER and started her up. Started on 1st TRY! AND Idled OK
But,,,,,,,,,,,,,,,,,,,,,,,When I Hit Throttle all the way,,,,,it STILL HAD almost NO Power JUST AS BEFORE......................
5. Looked UNDER Ski for Debre and there was none wrapped aropund the drive shaft or impeller.
WHAT SHOULD I DO NEXT??????????????????????????? I Hope I didn't do serious Dammage??
Thanks In Advance for any Advice Guys!
Seadoo Bandit ..................Gary
