cliff seary
On a 1997 Challenger 787 single engine boat which smokes on start up and while running terribly, found the mag rave valve had come apart at the spring holding the bellows together, what would cause this? Then the PTO rave valve had the nut broke or melted off which I replaced with a new solid cap and nut not rubber like the original rave valve and after a hour of riding, it totally melted to nothing taking the spring and red cap with it, before I replace these parts I would like to know what is causing this?
Thank you
Cliff.
Thank you
Cliff.
