Maybe a Stupid ?
pythonz281
Ok so i am a week old to jetskis but have rebuilt many 2 strokes ... Where does the lower end of these motors get their oil from does it use the premix oil to lube the crank .. Or am i just not seeing where to put the oil at !!! ... And also there is a greese fitting on the front of my motor towards the front of the ski what is this for and how offen should i be putting greese in it and what type of greese ....
thanks kenny :cheers:
Most every 2 stroke gets it lube from either oil injection or premix. All 2 stroke engines lube the crank in this manner. 4 strokes lube their crank with the oil sump in the bottom of the cases. For lots of information and specs on the 2 stroke engine, you might want to join as a "Premium Member" to have all the data needed to under stand the 2 stroke and 4 stroke engine difference. The seadoo forum, manual library is quite extensive and you can download or read about any seadoo you want in a pdf file or print it off for you own personal and private use. click on the link at the"manual link" at the top of the page for more information on joining.
Karl
Every 2 stroke ?
On my kx250 it has a lower crank case dipstick this oil in the crankcase does it lube the lower crank ? or are we just talking about pwc motors !!
And what about the greese fitting on the front side of the motor ?
thanks Kenny
That dipstick if for the transmission on the KX... I used to race 125, 250 and open class in the expert division. That oil is not for the 2 stroke engine part. Seadoo's don't have a transmission.
Karl
