Bought two 2001 GTS (717) from my brother last year. I knew what I was getting into with one of them. My wifes, : ) is a hoot to drive and has good power all around. Mine, haha, losses power on the top end. there is a variety on symptoms, I will bullit them for thoughts...
Both have same compresion (150) lbs
Both have been re-engined
The carb has been taken off at a dealer recently, cleaned and filters cleaned, he said he fixed it but nadda....
Both ski's impellers check out OK at the dealer
When we first put in the water they have the same top end speed.
After going cruising for a few minutes, they get warm. Mine will only go max speed 1/2 or a little more throttle. I can hold the throttle wide open or 1/2 open, same speed.
My brother said he noticed it would drop off when he turned left.
If I hit a set of good waves and keep it WOT, the ski will take off and pass hers. It catches air between waves and the RPMs max out, and the engine hold RPMs and it takes off. : ) Once I let the throttle off, I am back to the same situation. No top end speed.
Someone told me when they re-engined, they may have put the impeller 180 off? Not sure how that could account for the speratic topend.
Low compresion would seam to be the root cause, but, they are the same.
Could it be computer thing, when it warms up its in a safe mode?
The shop I took it to, was not a sea-doo dealer and did not have the diognostics equipment. Would a sea-doo dealer be able to read a code on a 2001?
I think the left hand turn thing my brother mentioned, just put enough resistance on the motor, causing it to loose RPMs and then it would not get back to full speed.
Any thought would be appreaciated before I take it back to the dealer and get drained for $$$$ again.
thx, from the rainy end of the country!
Karen
Karen
