newfiedoo
Hi all. Really enjoying this site. Great to be on here. A couple questions from a new owner of a 1999 Speedster SK.
Shortly after buying I noticed one of the inside bolts on the exhaust manifold was loose. I've tightened it, and after one ride it came loose again. Would this produce any symptoms in the running of the engine? I've also noticed that on the other manifold, there is a stud with a nut, instead of a bolt. What's the reason for the stud, and should I order one for the side that now has a bolt?
Second, I noticed one of the hose clamps fastening the sealing ring between the exhaust cone and the pipe was missing. I've replaced it, but noticed today on my maiden voyage that the engine didn't seem to accelerate smoothly. Is that consistent with a leak around that sealing ring.
Many thanks for your help!
