Lube Bendix
sammyg101
Anyway to hit the Bendix with wd40 with pulling the PTO?
If my cylinders are moving does that mean the Bendix IS working properly?
Sam
I just had a problem with my bendix i took my exhaust off and removed the starter and i sprayed some w-d40 in where the starter go and moved things around with my hand since i was there i replaced the starter and put everything back together and it fired right up.
yes if your able to crank from the starter button and the engine cranks over yes thats a good thing.
