Well, I was going to explain, the screw with the screwdriver is the idle adjustment, if you look to the left the screw with the "T" handle is the LS adjustment screw, this screw needs to be set at or near factory specs. usually about 1-1/2 turns out. The idle should be set for about 3000rpm out of water, 1500rpm in the water.
Lou
