I have a 98 gsx limited, I bought it about 1 1/2 months ago, i was unable to ride it until a week later and found that it had no power & the rpm wouldn't come up, I did some checking & found the rear cylinder wasen't getting fuel, I took it to a local boat repair that freinds said was very good with these things, they rebuilt the carbs and hooked water to it to test run it and found the head pipe broken, it took about a week to find a used pipe(ebay saved the day) found a $600.00 pipe for 90 bucks yippee, got everthing together & finally took a cold ride, got cold in Va, ski had plenty of power comming out of the water but the rpm doesn't seem to be were i think it should be at wot, it's only turning about 6500 rpm, according to seadoo manual the rev limiter is 7200, is there anything i can check, any advice would be greatly appreciated
Thanks David N
Thanks David N
