I accidentally ran my Seadoo challenger 180 sc with low oil. The alarm only came on once for 2 seconds than went off, the oil was at the bottom bend of the dipstick. Did I cause any damage?
You are probably fine. That sensor is suppose to tell you when you are low, it did its job. Add oil and go for a test ride. Do NOT overfill is. To high creates crank case pressure and the engine looses performance.
I just got it changed and the dealer I went to has not been the best in the past, so I am guessing they didn't top it off since there are no leaks and it isn't burning it, this was the first run since it was changed.
