Low oil light and sometime dess beep
99XPLim
I just aquired a 99 XP lim. The low oil light stays on , After reading posts im sure its the Sending unit, Is there a place on the forum that shows how to replace it ? Im sure I can change the part out .But Is there a bleeding process to make sure ur motor doesnt suffer air pockets ? Or does it act like a car , Replace oil and start and run and its good :)
Welcome to the seadoo forum 99xplim. You should add you model and year to your avatar so we can help with any future problems with the correct seadoo information. First I would just add oil and see if it goes off. If it doesn't work unplug the sensor and see if the connector is dirty. The sensor just slips in the top of the injector tank. No need to bleed anything.
Do you have a seadoo shop manual? If not here’s an idea for you. You could join as a "premium member". As a premium member you can down load a authentic seadoo manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
