low gas light on
jasone
i have a 1996 gsx and when i connect the battery to the seadoo my led low gas light comes on and stays on, any ideas what might be the problem. and yes it has almost a full tank of gas. any ideas on what my problem might be.
your fuel sensor is bad, it's in the fuel tank. a quick fix so you don't have to listen to the annoying low fuel beep is to unplug the 2 wire connector(pink and pink/black) and put a jumper wire in and your tank will read full. To fix, pull the fuel baffle asm, many times it's just the float and seadoo has a new float replacement kit for like $8.
thanks for the info. any idea on how hard it is to pull the baffle assembly?
