Low compression in cylinder
bigtuck
Just bought a 2001 GTX and took it to the lake and it ran great for 15 min then died and will not start, compression in #1 is 30psi and #2 is 80 psi whats going on with it?
time for rebuild, stud....ideal is 150psi, under 100psi isn't good...check to see, if oil pump is blocked off, or line blocked off, to run premix...
