Loud constant "beep tone" wont stop after low engine oil light has gone off and oil topped off.
Trediddy4
2003 challenger 240 2 stroke engine. Had low oil so the oil light came on and the 4 beeps started. Filled oil reserve and the small tank mounted on the engine. Engine oil light has now gone off however the constant beep tone is going. Gas gauge doesn't work and is on empty, however the tank is full of gas. Do I need some sort of factory reset performed to get the tone to go off? Thanks in advance for your help!
Some alarms are fuel level related. Since you have a gas gauge problem, the computer is getting bad info. Usually the sender in the tank. Unfortunately, it's a seadoo part. But, you can get repaired units on ebay. Not very hard to replace, but start the job with a less-than-full tank. Tip the bow down helps a little.
