I have tons of parts. Some are from parts skis, and some are from previous builds. PM me. Very Reasonable prices
Prices will include shipping when given
Skis & Ski Parts
UMI RACING HANDLE BARS (Bars Only)
R&D Steering Nozzle (Complete)
97.5 Seadoo GSX Limited (Hull for sale, local pickup)
- Hood (with mirrors) *Great condition
- Handle Bar Cover *Great Condition
- Jet Pump 155.5 *Great Condition
- Steering Nozzle
- Drive Shaft
- Seat [Red] (needs recovering)
- DESS Post
- Choke Cable
Multi-Function Gauge *Great Condition
Speedo *Great Condition
2000 GTX Millenium Ed.
- Complete Wiring Harness (Everything)
- Oil tank and sender
- Water Box
- Ride Grate
- Ride plate
- Air boxes
- A few other misc parts
- Reverse Gate (Any 155.5 Jet Pump)
- Steering Nozzle (Any 155.5 Jet Pump)
Compass
155.5 Jet Pump Housing (Good wear ring no impeller)
- Impeller Shaft
96 GSX JET PUMP (needs wear ring and impeller [impeller might be salvagable])
94 Seadoo XP
- (2) Water Boxes
96 Seadoo SPX
- Jet Pump
- Gas tank
- Water box
- Choke cable
X4 Style Hull Seat (Black) [Good condition, pen size hole]
MOTOR PARTS
951 Carbed (Gray)
- Flywheel & Magneto
- Stator & Cover
- Starter Bendix (3 teeth missing..possible core?)
- Reed Valves
- Exhaust mounts
- Motor mounts (any 951)
- PTO
787
- Mag side Carb
- Rave Valves (no bellows or caps)
- Cylinders (3 bolts broke off)
- STD BORE Pistons and Rings
720 (Single Carb)
- Crank Cases (Mint) SOLD
- Intake Manifold w/ Oil Pump
- Crank Cases (Fair/core?)
- Cylinders (.25 Over)
- (2) Cranks - Core
- Exhaust
- Water box
- Carb
- Motor Mount Plate
657x
- Stator and Flywheel Cover (Uncut wires [4 wire connector])
- Flywheel
- Motor Mount Plate
657 (PARTS MOTOR)
- Cylinders (1 has chip in sleeve at the top)
- Exhaust Manifold
- Crank
- Motor Mount Plate
587 (PARTS MOTOR)
- Cylinders
- Exhaust Manifold
- Crank
- Flywheel
- Motor Mount Plate
Throttle cables, Throttle levers, Dess Posts, buzzers, oil senders, fuel baffles, etc.
Plenty more parts, just ask I may have what you need!
Skis & Ski Parts
- Steering Nozzle
- Drive Shaft
- DESS Post
- Choke Cable
- Water Box
- Ride Grate
- Ride plate
- Air boxes
Compass
- Impeller Shaft
94 Seadoo XP
- (2) Water Boxes
96 Seadoo SPX
- Jet Pump
- Gas tank
- Water box
- Choke cable
MOTOR PARTS
951 Carbed (Gray)
- Stator & Cover
- Reed Valves
- Exhaust mounts
- PTO
787
- Mag side Carb
720 (Single Carb)
- (2) Cranks - Core
- Exhaust
- Water box
- Carb
- Motor Mount Plate
657x
- Flywheel
- Motor Mount Plate
657 (PARTS MOTOR)
- Exhaust Manifold
- Crank
- Motor Mount Plate
587 (PARTS MOTOR)
- Cylinders
- Exhaust Manifold
- Crank
- Flywheel
- Motor Mount Plate
