!!!!!lost Power!!!!!
pooskid
hey im from new zealand and i have a 2002 seadoo xp 951 i have just got the top end rebuilt new piston and rings ect and i was riding it for about an hour and it lost bout half the power was wondering if any 1 has any thourts on this i did put the engine in myself so thourt sumthing could have come off mayb, any help would be much appreciated.
Thanks shane
Shane what is the compression of the cylinders? I would start with a compression test as you said you just did a top end repair, then you can go from where your problem started. Here is a run down on the compression test for starters;
You'll need a compression tester. Go to any auto parts store and buy or rent one. I think they sell for like $25.00 USD. The compression gage, will screw in the cylinder head in place of the spark plugs. To test compression, remove both spark plugs. Place spark plug caps on the plug cap studs near the cylinder head to ground the empty caps. This completes the circuit of the ignition electrical system and prevents any electrical problems from the caps being un grounded. Using the correct adapter for the threaded end of the tester,( same length of the spark plug threads length)screw in the tester in one plug hole. Hold the throttle wide open. Push the start button. Watch the compression gauge, when it peaks out at the most compression, let go the start button. Read the psi number. I would do it 3 times to be sure it is accurate. Check both cylinders the same way. The ideal compression is 150 psi per cylinder. If it is less, it's not a problem as long as they are close to being the same. If the psi is less than 90 it might need be time for a tear down and a rebuild. If the psi in 1 cylinder is say 140 psi and the other is 80 psi you need to tear down and repair. This difference is a lot then there is a problem. I hope this helps you.
Karl
