henryb
Well my arch nemesis strikes again! It seems I've had a bit of a run of bad luck... Today coming in from a morning cruise, I lost almost all power. Speed dropped from 40MPH to 10 in one moment. I thought I hit a huge clump of weeds or something? So I idled into doc. Checked the impeller, sure enough it was jammed with weeds, but our bay is quite weedy!
Cleared the weeds about an hour or so later and tried again, still not running right, low on power, barely holding an idle? I remember Dr Honda suggesting to someone else to check for a cylinder that is not firing by touching the spark plug after running engine for a short time... If plug was firing, it would be warm to touch. But I noticed that the lower 2 cylinders on the drivers side were cold, were all of the others were warm.
I'm guessing it is a coil pack or something like that, if I recall correctly this engine has 3 ignition coils that control 2 cylinders each? Or am I out in left field?
