Scubadave16
1996 Sea Doo Challenger 787. So after replacing my wear ring (OK, the shop did it). my boat ran OK for a while, but this week after sitting a couple weeks I took it out and it started and idled just fine all through the marina. When I opened up full throttle out in the lake it revved up for about 3-4 seconds, then hiccuped, backfired and wouldn't go above about 3500rpm. so idled back. engine "pops" once in a while all the way back. So I checked the fuel filter- clean. sprayed some sea foam in the carbs- nothing. no matter what I do it doesnt rev up and it backfires quite a bit when I open the throttle. I even sprayed sea foam directly into the fuel filter- nothing except backfiring. with the throttle wide open it runs maybe 3500rpm. every once in a while it almost sounds like it will rev up to full RPM, but then backfires and goes into a fairly smooth low rpm. nice water stream. plugs a bit dirty, but nothing really scary. Like i said, the shop had it in June and it was running fine for them, so this is something new. What should I check next?
