gaillynn66
I had my boat out and it had been running great and pulling a tube off and on. Everyone was in the boat and when we went to take off the boat did not have any power. the engins would rev but it would not go beyond 5mph. I took it into a repair shop and they said that it had some seaweed in it but all they found were the ware rings were worn and needed to be replaced. I asked if they had done anything that would change the performance if I took it out again and they said no. I took the boat out again and it ran fine. Not enough power to pull an adult in a tube but definately better than before. Played on it all day with no trouble. (did not pull a tube). Took it out again a couple days later and it ran fine heading out into middle of lake. We stopped engines and drifted for a couple hours. Started back up and it was a repeat of the problem mentioned above - no power. Got to a sand bar and turned off engines, looked in the engine compartment and everything looked fine. Pushed the boat for a bit to get out of sand bar (the boat was off for about an hr). Started the boat back up and it ran better than it had all year. Got near the channel to take it in, slowed the engines, then when I throttled up again to add a little speed to take it in and again it did not have any power. (when it was acting up after drifting I started one engine at a time (by itself) and one sounded rumbly and wonderful while the other sounded a bit starved for gas or oxygen or something, it just didn't sound right. Any ideas what this may be or what I can check. I do not believe the ware rings being replaced will fix my problem. Thanks for any advice you could give!!
