OGs Active Member Jun 12, 2020 #1 I have a 01 gts and i cannot seem to figure out why it has no power. Battery is good, cables are good starter relay new rectifier, all new fuses , start button is new , i cleaned up the connection spots and still nothing. What should i do?
jts32 Active Member Jun 15, 2020 #3 With the key off, do the gauges power up when you hit the start button? You said the starter solenoid was replaced. Is the small red wire on the correct terminal?
JeremyD615 Well-Known Member Jun 15, 2020 #4 Take a multimeter and see if you have power at the solenoid. Do you know if your buzzer works?
Tyman2020 Well-Known Member Jun 15, 2020 #5 http://seadoomanuals.net/download/pdf/service/manuals/2001/2001-seadoo-shop-manual.pdf Page 548 Check grounds Do you have power to gauges?
OGs Active Member Jun 15, 2020 #6 jts32 said: With the key off, do the gauges power up when you hit the start button? You said the starter solenoid was replaced. Is the small red wire on the correct terminal? View attachment 48876 Click to expand... jts32 said: With the key off, do the gauges power up when you hit the start button? You said the starter solenoid was replaced. Is the small red wire on the correct terminal? View attachment 48876 Click to expand... dude , most rookie mistake I’ve made ! Thank you broooo
OGs Active Member Jun 15, 2020 #7 Guys thank you for your help. As jts32 said it was the wire. Smh but thank god im up and running. I’m the happiest man on earth rn llol
jts32 Active Member Jun 15, 2020 #8 OGs said: Guys thank you for your help. As jts32 said it was the wire. Smh but thank god im up and running. I’m the happiest man on earth rn llol Click to expand... Awesome. Glad to hear it was something simple. Happy boating!
OGs Active Member Jun 16, 2020 #10 Same to all. Literally I wouldn’t be as far as I am right now without the help of everyone on this forum.
