What do you mean by "true ignition source".[/QUOTE
Found this in a forum this might help to show you why Iam looking for a true ignition source.
I am putting on the finishing touches on my PAC battery isolator. I have added a second battery only for the radio. My question is this....I have to run a lead to switched power. For example when the key is in the on position and the boat is running the isolator will open allowing for both batteries to charge. When the key is off or in accessory mode the isolator will close allowing the stereo to only operate off the second battery. I looked under the ignition and noticed the following wires: red, red with yellow stripe, two purples, and black. I am assuming the red is start power and the red with yellow is maybe accessory? Can somebody help me so I put the isolator turn on lead to only switched/on power. Thanks.
