I test drove a 2008 180SE today, it was my firs time on one. I have a some questions or concerns from what I saw.
1) The max RPM the boat was developing was 7300-7400RPM. Is that normal? I saw it jump to 7800 one time out of the hole very briefly.
2) The boat seemed to pull a little to the right at high power and low power settings. Is that normal?
3) I occasionally heard a little whine from the engine and I assume that was just the turbo charger, does that sound accurate?
4) The boat has 75 hours on it, what is the maintenance schedule from here?
5) It seemed to bleed speed fairly quickly in turns, I assume that is normal since you are using the thrust for steering?
Thanks for any help.
Thanks for any input.
