Any 'checklist' threads started for buying a used 2003 seadoo boat w/Merc. engine? Looking at one today and need advice on what to watch out for.
I don't know if there's a formal checklist, but inspecting any boat is pretty much the same.
Number One Rule: Don't buy it if you haven't driven it yourself on the water. Lots of boat engines run fine "on the trailer" but reveal problems once they're in the water because now the engine has a load on the impeller.
Another good and fast indication is the cleanliness of the engine compartment. It's easy to ignore because it's out of sight for most people. If that's been kept clean, it's likely the owner is conscientious and attentive to the other aspects of boat ownership - like proper engine maintenance.
Most of a sportboat's value is in the engine(s). It's really an engine that happens to come in a fiberglass wrapper. So pay attention to the engine. If the first two items above check out fine, go over the engine carefully. General cleanliness is a good starting point. Do a compression check on all cylinders (they should be within 5-10% of each other). Look at the spark plug electrodes to see how things have been going inside the cylinders. Look at the fuel filter(s); they're really easy to change, so if they're dirty and nasty the owner probably ignores all other maintenance too. Look at the wiring on the engine, checking for discoloration or other signs of overheating.
Check the fuel lines on the engine/carbs, and to/from the fuel tank. Cracking, splitting, drying out, brittleness/stiffness, etc. are all signs of neglect.
You're talking about a 2-stroke engine, but if you end up considering a 4-stroke you should sample the engine oil to check for contaminants, particulates, etc.
On the drive system, "dip" (stick a clean screwdriver into) the lubes at the front and rear of the impeller shaft. There should be no discoloration, no foam, no metal flakes, etc. Obviously examine the front and rear and edges of the impeller for any damage whatsoever. Check the wear ring around the impeller for nicks, gouges, any sign at all that anything but clean water has passed through the jetdrive. Check the clearance between the impeller and the wear ring - they should be tight with as little space as possible. Grab the impeller shaft and try to wiggle it in every axis; you should feel just the slightest clearance but nothing sloppy and no rattles.
Check the steering nozzle and the thrust reverser for smooth operation and any signs of damage, paint wear, etc.
Remember, if it's a jetboat then you're really inspecting a big, powerful water pump. Look for anything that doesn't appear proper for something that should be pumping water. Nicks? Gouges? Deep scratches? Those indicate something other than water passed through the jetdrive, perhaps rocks sucked off the bottom of the lake or floating debris that the owner didn't bother to avoid.
And I haven't even mentioned the rest of the boat. Obviously check the console controls, seat fabric, fittings, cleats, etc.
This should get you started. I would allow at least 2-3 hours to properly review a boat on its trailer. You will need tools to do it right. Take at least one additional person with you because multiple sets of eyeballs will see different things.
Report back!
