jmartin915
So then while pulling the rotary shaft out is there anything else I would need to do or know before proceeding pulling it out. I am using a make shift puller with a bolt that matches the thread inside the rotary shaft and a much larger socket (so it will not damage the splines on shaft outside the motor). Also the manual shows the pistons still in the motor when removing the retaining ring but when pulling the shaft there are no pistons. Am I going to have to pull them too?
jmartin915 said:I may have solved the problem but have to wait for some parts (I damaged the coils beneath the flywheel removing it). But I think the problem was the cooling temp sensor. Before tearing into the engine...When the machine was started it smoked a bit but then after running would die. I believe the sensor would cause the machine to run to lean when the motor was cold but when the machine was hot it would dump lot of fuel in to cool things down...which would explain why my new spark plugs would be getting wet (really wet). The faulty sensor would flood the engine. Am I on to something?
[QUOTE: Seadoosnip;] No, your not onto something, not if your talking about a 98 model 717. There are no sensors on this model engine, that support any changes to the engines performance, just a temp sensor that will trigger a beeping alarm, if you run the engine hot. Seems you may have a fuel issue, possibly in the carbs or you may have bad compression. The smoke is coming from seepage of the rotary seals, which is normal as the engine wears, getting older. When it gets so bad, that the smoke doesn't clear up, then your going to leak so much into the pistons that it will eventually hydrolock on you.......
