I want to make sure my high speed adjusters are turned in all the way.
I have a 1996 Seadoo GTX 787cc.
On the PTO carb, or the one towards the rear of the ski, I am pretty sure I found it. Its just like a rubber plastic adjuster, that you can use a flathead screw driver on.
However on the Mag carb I am not postive that I found it.
What I found is an adjuster, in about the same location as the other carb, however, it has a "t" bar on it, unlike the other carbs adjuster. The only thing I can think of, is yes this is the high speed adjuster, and they put a "t" bar on it, so it can be adjusted. If it was a flathead adjuster, there would be no way to adjust it without taking the entire airbox off, and maybe even gas lines.
Am I right?
Front carb high speed is "t" bar, rear carb is the slotted plastic like flat head adjuster?
1996 GTX 787...
Thankyou for your time....
Am I right?
1996 GTX 787...
