little problem with 95 xp
picklert
Just got this ski about a month ago and love it. The only problem I'm having with it is when I take off. If I gas it hard from an idle it seems to slip(kind of like a clutch slipping)or maybe miss. It will do it 2 or 3 times real fast and then its fine. When it does it, it only a second long maybe shorter. It runs fine otherwise. Anybody have an idea what it could be?
RPM's
It sounds like what your describing is a propulsion problem. If your experiencing high RPM's and no speed like it's slipping then most of the time you need a new wear ring. Using a feeler gauge with 30 cm (12 in) blades, measure clearance between impeller blade tip and wear ring. Measure each blade at its center. Clearance should not exceed 1.0 mm (.040 in). If clearance is greater, disassemble jet pump and inspect impeller and wear ring.:cheers:
Thanks guys, I had a feeling that it might be the wear ring. I will check again but I dont think the grate is broke.Is it better to use a factory piece or aftermarket?
Just buy one off the Parts link on this site. Order an impeller removal tool as well or just go pick one up if there's a dealer close to you.
