Canadian06
I have a seadoo challenger 2000 with a 240hp merc M2 jet drive and Im having some trouble with it going into limp mode. Won’t go over approx 1200 rpm
if I launch the boat, start it up and cruise non stop it runs perfect. If I turn the motor off then start it again it goes into limp mode until the boat is taken out of the water for a few minutes. It will run fine if relaunched.
I should also mention that the previous owner installed a toggle switch by the throttle because there was an issue with the factory throttle. He said to move the switch forward or into reverse as needed. When the fault happens, I’ve tried moving that switch/restarting the motor and it does nothing
any Help would be appreciated
