Nate Surveyor
If you are running a oil injection system, and you delete the oil injector, and pre-mix the gas, then the fuel you run is THICKER than straight gas.
The closer to 20:1 you get, the thicker it gets. (20:1 is the richest we have run)
So, you have to OPEN up the carb, and let more gas through it, the richer you get with oil.
If you are all jetted up for running 50:1, and you suddenly run 32:1, you could go too lean, and burn up the motor, due to a lean condition. Caused by the THICKER (more viscous) mix.
So, when you settle on a mix ratio, and have everything tweeked up right, then you get somebody else's pre mix, that is another ratio, you can have trouble.
Same thing can happen if you are jetted for 32:1, and then you run 50:1, it can run too rich, (juicy) and now you foul the plugs.
Anywhays!
Remember the viscosity of your fuel!
Nate
Anywhays!
Nate
