LED bulbs 2011 210 SP
210sp!
has anyone been able to replace the inboard courtesy bulbs for LED? like a straight replacement? or did it require new housing etc...? in any case, what did you buy? where? cost? thanks!
Also, it appears the white plate in front of the casing is really tight. how did you manage to pop it open? or is it just that tight?
I used a razor blade to get under mine. Once lifted up enough, I used a screw driver to pop the rest of it off. I put a piece of thin plastic packaging between the boat and the blade to protect the finish.
Bottom side of mine has a little screw driver slot to pry the cover off. Ordered the same LED lights provided in Kernal's links and hope to have them in by this weekend:)
Got the LEDs in and they worked well. Thanks for the recommendation Kernal.
Also ended up doing my cockpit gauges (different LEDs) except for the fuel gauge as that one looks like it has to be taken apart to replace the bulb.
Lights are a bright blue although they may appear to be more dark blue or purplish in the pixs.
