Lean or from water?
Albysure
07 180 se
Hey guys.....was winterizing the boat and got to fogging the cylinders and noticed my plugs looked pretty white....this is my first 4tech...I'm use to 2 stroke seadoo's and I know white isn't good on the plug....I just had work done to it due to a seal failing on the exhuast gasket causing water to get in crank...it was under a warranty so the motor was taken out and dipped and all replaced...
Ok so are my plugs white from running lean or was the dealer cheap and left in my old plugs?
What should I do? Just replace plugs at the start of season and see if it happens again?
I wouldn't be too concerned. 4-stroke engines generally have much whiter plugs than 2-stroke. I thought the same thing when I got my 4-tec.
Yeah they don't look bad, I would replace them and check them next season after a long ride.
