DLB
i discovered my j-pipe has like 7 pin holes in it and it's spraying water onto the engine. can i repair the holes with something? the holes all seem to be in the same area right where the welds are. i have found a used j-pipe for sale at a reasonable price but it is a white label pipe and mine (being a 215HP engine) has and should be running a red label pipe. from what i gather the red label pipes are made from a more heat resistant metal. will the white label pipe really make a difference? has anyone used the white label when you should've used the red? what were your results? thanks!
