Bad news is you have a leak, or two. As long as the pistons and cylinders are good then all you should have to do is replace gaskets which is a good thing, not super difficult, but a little time consuming.
As stated above, if the machine is worth it, this is a good time for a top end rebuild. If compression numbers are good though and things look smooth just doing gaskets is a common thing.
