bammajamma
I'm sick of leaking oil from the tank to the to the engine. so this is what I did. I used
Hose Size Inches: 1/2
Mounting Hole Diameter Inches: 13/16
Maximum Hull Thickness Inches: 1-1/4
O.D. Flange Inches: 1-1/2
Model Number: 0328DP4
http://www.amazon.com/Perko-Thru-Hull-Fitting-Hose-Plastic/dp/B0091KUJMO
I went to the hardware store an got neoprene washers 4 each
then I used a size step drill and drilled the holes to fit tight and I also added two ball valves, and (3)1/2", (1) 3/8" threaded barbs to fit on the ball valves.
I added them if I ever need to drain the tank or if an engine leak I have an option stop the leak I hope.
now for leak test, it has been sitting for a week and no leaks so far. :lol:
