Leak between hull and deck joint
Deeket
Have a 1987 seadoo speedster leaking at factory joint between hull and deck
Has anyone ever fixed this before. I gather I take off the rub rail and inspect the rivets Drill them out and use 3m 5200 or 3m 4000
Any guidance would be appreciated
Its been known to happen, and as you have already gathered... it's a pin in the butt job. Drill out all the rivets, and you may actually be able to separate the top and bottom hulls.
