I would start with new plugs. You would be amazed at what a new set of plugs can cure. Then if that doesnt fix it, id start loking at typical fuel issues. That includes making sure you dont have the dreaded grey temp fuel lines, new filters and then rebuild the carbs. Since it seems to be isolated to 1 engine, i would suspect plugs or carb issue. Fuel cleaner is a waste. I try to start with simple & cheap and go from there.
